>> What differences are there between the different file versions of DWG files? eg 2013, 2010, 2007 etc.
The DWG file format is not public, so at the first point of view only Autodesk developers have that info.
There is one site >>>click<<< from different members trying to be compatible with DWG format, maybe you can get there specific informations.
>> I have been asked by one of our engineers if we can set AutoCAD to default to save in earlier file formats.
My opinion to that: never ever 😉
Besides of performance issues (destroying objects to make them available for old AutoCAD releases as well as "healing" them to get them back to current state when opened with current AutoCAD) you might experience sometimes file-defects (objects that are defect then).
So I would never save back files I'm working on, if anyone else needs files I created with current AutoCAD I would create a copy of my file in an old format or the partner needing my files in an old format can use >>>Autodesk Dwg TrueView<<< to open my current file and create a copy in the old format by himself.
>> What would we be losing by simply saving all our drawings to a very early version?
All geometry types not available in that old AutoCAD releases are converted to "compatible for visualization" objects and the older the DWG format the more objects are converted. That depends especially what types of objects you are working with. But even the simple object like a LINE might have issues if you used something like e.g. transparency. There is no list available which object changes it's properties/internal data-structure when saved back. But the older the format is the more problems you'll get with that.
My last words to that: save back only copies of your files, but never your working file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
