AutoCAD Forum
AutoCAD 2015. Annoying Automatic Change to ToolBar
20 REPLIES 20
Message 1 of 21
3370 Views, 20 Replies
When working on the Layout tab, and moving from Model space to Paper space, the toolbar on the top automatically goes to "Layout Tools."
HOW DO I STOP THIS!?!?!!  I really want to stay on the HOME tab with all the tools that I need to do my work.
Thaddeus
20 REPLIES 20
Message 21 of 21
sarienne_friesen
in reply to: nestly2
I can confirm, this worked for me (using AutoCAD Map 3D 2022). I have attached images of where to look.
Enter the "CUI" command for the CUI window, then under (Customize tab > Customizations in All Files...) ACAD > Ribbon > Contextual Tab States > Layout Tools > Contextual Layout Tools. Then (in Properties pane) under General, see "Contextual Display Type" > change dropdown to "Full without focus".
I needed this in order to keep on Annotate tab, because (for whatever reason... I have yet to find out), using the "DIM" command in paperspace lags to all hell, but clicking "Dimension, Linear/Aligned, etc" buttons in the toolbar is relatively normal. I have tried many of the suggestions for reducing layout/paperspace/viewport lag and none work. So this is my work-around until I figure it out.
AutoCAD Inside the Factory
