SUPERHATCH-BLANK SPACES
fcernst
Mentor Mentor
fcernst
Can anyone tell why I keep getting blank areas when trying to Superhatch with my block here?
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Kent1Cooper
SUPERHATCH works with orthogonally-oriented rectangular areas [watch the process as you use the command].  When you specify such an area around that Block, it necessarily includes the empty corners.  Define your Block this way:
and you can do it:
Or, Rotate the outline -45°, define the Block with horizontal bands, SUPERHATCH, and Rotate the result with the outline back 45°.
Kent Cooper, AIA
fcernst
Hey thanks!
Fred Ernst, PE
C3D 2026
Ernst Engineering
