Array switching to a 3D display (why?)
hanslammerts
Message 1 of 49
hanslammerts
(Check the icon to see the switching of display mode)
It feels like the new Array function was meant ONLY for 3D use. Which i find quite a silly thought.
Noticed this behaviour over several new AutoCAD releases and it keeps bugging me.
Autodesk, can you please stop this mechanism?
It is a useless waist of time / computerpower.
https://www.youtube.com/watch?v=8ZimGtiziSc
Replies (48)
Message 21 of 49
john.vellek
Hi @hanslammerts,
Thanks for updating your thread on this issue. I have confirmed that the team is aware of this behavior. I am not at liberty however, to discuss any timeline for when this will be adjusted.
John Vellek
Message 22 of 49
hanslammerts
'Not at liberty' ?
You mean, don't expect any improvement because AutoCAD developments is a stage zero budget.
Message 23 of 49
Discussion_Admin
@hanslammerts wrote:
'Not at liberty' ?
No more like .... FTC rules and all that.
DA
Message 24 of 49
eidam655
Hi @john.vellek ,
Were you successful in figuring out why this might be happening? Is there a setting in autocad I could change? The Visual Style change makes my work much slower than need be...
Thank you!
Message 25 of 49
hanslammerts
Does new AutoCAD 2021 have any improvement. I didn't recieve feedback. Does this development team have an opinion?
Message 26 of 49
hanslammerts
Switching to AutoCAD 2020 : This still is in it? Why?
Message 27 of 49
RobDraw
So you can have another reason to hate Autodesk.
Rob
Message 28 of 49
hanslammerts
Its a confirmed bug. And i am not a great fan of bugs. Not being fixed year after year. Hate me for that. You just keep paying your your bucks and think it's soulgoodman.
This 'forum' is just a good way to channel frustration where it needs to flow.
See you next year?
Message 29 of 49
RobDraw
No, it's not. This is a user help forum.
See you next year?
I hope not.
Rob
Message 30 of 49
arturolemus
Wow! Same issue here! Array 2023 is awesome! Just please, please remove the 3D wireframe when editing the array. A 2D wireframe is light and quick to edit and move on. No need for fancy 3D background that takes all your resources.
Message 31 of 49
hanslammerts
See you in 2024!
Message 32 of 49
mellishmcw
robraw hurt itself in its confusion.
Message 33 of 49
arturolemus
You’re confused!
The issue is there. I own a high, high-end computer and as soon as try to use arrayedit command the whole background goes into 3D wireframe mode. There is no need for 3D wireframe. 2D wireframe is just perfect.
I was able to create a macro that automatically change it to 2D wireframe. Just feel bad for all thousands of users that had deal with it.
Message 34 of 49
RobDraw
Thus thread is a bloody mess.
Rob
Message 35 of 49
hanslammerts
Yes. Autdesk forum is a waist of time.
Message 36 of 49
arturolemus
For what it's worth!
Here is the macro to modify the command ARRAYEDIT
^C^C_arrayedit _s \$M=$(if,$(or,$(and,$(eq,$(getvar,"tilemode"),0),$(eq,$(getvar,"cvport"),1)),$(eq,$(getvar,"blockeditor"),1)),_vscurrent;,_vscurrent _2)
You can go inside the ribbon directory and find Rectangular array options > Tabs > Rectangular Array Options, them modify the macro. 3D wireframe no more.
Message 37 of 49
TheCADnoob
Yet here we are year after year lol
CADnoob
Message 38 of 49
RobDraw
So are your posts. Always bashing Autodesk and insulting users.
Rob
Message 39 of 49
imomani
Any solution for now? the problem seems to be still happening in 2023!
For me, I try to switch back to the 2Dwireframe view which can help a bit.
Message 40 of 49
mellishmcw
It seems robdraw hasn't posted since late August.  One minor improvement to the forums.
