Array switching to a 3D display (why?)
hanslammerts
Message 1 of 49
hanslammerts
(Check the icon to see the switching of display mode)
It feels like the new Array function was meant ONLY for 3D use. Which i find quite a silly thought.
Noticed this behaviour over several new AutoCAD releases and it keeps bugging me.
Autodesk, can you please stop this mechanism?
It is a useless waist of time / computerpower.
https://www.youtube.com/watch?v=8ZimGtiziSc
Replies (48)
Message 2 of 49
john.vellek
Hi @hanslammerts,
I apologize but I am not following the issue you are describing. The video is pretty fuzzy and I am missing out on what the problem is.  Can you perhaps explain in a bit more detail what the array issue is and include a couple of screen captures?  I am happy to see if I can find a solution for you.
John Vellek
Message 3 of 49
edwin.prakoso
I think what @hanslammerts wants to say is the Visual Styles changes from 2D Wireframe to 3D Wireframe when he activates the Edit Source command.
Cheers,
Edwin Prakoso
Message 4 of 49
hanslammerts
That is exactly right Edwin! Here is a animated gif for you.
A simple line in 2D my video card can handle that pretty good. ..but as you might know ...
doing more complex 3D modelling switching from 2d to '3D conceptual' styles and vice versa does hold up and consumes computer power!
So... Save the world ! Save Energy ! 😉 .. Save my time and don't switch when i don't tell you to..
capirsi2017-09-28_11-01-12.gif?
Message 5 of 49
john.vellek
Hi @hanslammerts,
Thanks for the clarification.  The Array command does allow you to array in three dimensions which is what you are seeing the behavior do but I am not sure why the visual style is changing. Mine does not do that. Does this behave differently with different types of geometry? Can you share a file that displays this behavior?
John Vellek
Message 6 of 49
hanslammerts
What version are you using? I'm on 2017.
It is in AutoCAD, not in files
Message 7 of 49
john.vellek
Hi @hanslammerts,
I am currently using AutoCAD 2018 but I have tested this behavior in 2017 and 2016 on my computer as well.
Perhaps I am missing some steps.
Here is what I did:
  • Created a new drawing and verified that 2D Wireframe was set to be current.
  • I draw a line
  • Next, I start ARRAY and make a rectangular 2D array.
  • I double-click on the array and the array edit ribbon appears. The Visual style is still 2D Wireframe.
John Vellek
Message 8 of 49
hanslammerts
Did you EDIT array ???
Message 9 of 49
hanslammerts
Apparently not.
Message 10 of 49
john.vellek
Hi @hanslammerts,
Yes, I did edit the array by adding an extra column to my rectangular array. I apologize that I forgot to type this step into the list.
Is it possible to share a sample file? I would like to see if there is something different in your file compared to mine.
John Vellek
Message 11 of 49
hanslammerts
Behaviour STARTS when Editing is activated
Message 12 of 49
hanslammerts
Strange than. Probably a dutch version of AutoCAD;-)
Message 13 of 49
hanslammerts
Will get back to you later ok.
Message 14 of 49
john.vellek
Hi @hanslammerts,
In case this is unique to the Dutch version of AutoCAD, I have brought the issue to the attention of the localization team.  I will try report back with any findings.
John Vellek
Message 15 of 49
edwin.prakoso
Hi @john.vellek,
It is not a localized issue. I can reproduce it on AutoCAD 2018 English. You can see it in the screencast. The UCS changes when the command is active, showing that the Visual Style is no longer 2D wireframe.
Cheers,
Edwin Prakoso
Message 16 of 49
hanslammerts
Wow, i didn't know you guys have Dutch edition, was meant to be a joke.. Lol.
So it is confirmed to be a wider issue now? My colleguas had it too.
Message 17 of 49
john.vellek
Hi @hanslammerts,
I am sorry, I figured you meant Deutsch but I typed Dutch like you did. My error!
Thanks @edwin.prakoso, your video was clearer to me and I am now able to reproduce this behavior as well. Let me do some research on this and I will get back to you.
John Vellek
Message 18 of 49
hanslammerts
On other thing about the 'Edit mode' of an array.
Somehow my right mouse button is working not as it should.
It ignored the setting i work with
Feels like a bug, Hope Autodesk can fix this too with new release coming.
Message 19 of 49
hanslammerts
Tested this in 2019.
Still the same.
Silly and useless swithing of visual styles, not responding correctly keyboard..
I'll think i have to come back here in 2020 or so. Annoying bug.
Message 20 of 49
hanslammerts
