I am trying to batch plot to a pdf with the monochrome plot style.
Unfortunately the best I can get is that the monochrome plot style is applied to the drawing that I have opened but not to all of the other drawings that I have added to the batch plot.
Here I have opened the first drawing of the drawings that I wish to batch plot
Next, I have modified the default page setup for the drawing to the monochrome plot style
Next I have selected batch plot
Next I have added the required drawings to the batch plot
Next I have applied the default page setup of the original drawing that I opened to all of the other drawings in the batch plot.
Next I publish the pdf.
In the resultant pdf,the monochrome plot style is only applied to the orginal drawing that i opened (01) and not the others (02,03&04).
Any information that would assist me in resolving this issue would be most appreciated.
thanks.
Solved by john.vellek. Go to Solution.
Solved by RobDraw. Go to Solution.
I say the following:
It is possible to print everything in 10 minutes, and then do a new thing. Get more pay.
And do not do anything at home. And you do not need to leave for the night - there may be mistakes, which will have to be redone the next day.
But most do not think about it. They either continue to print with their hands or are looking for a “big red button” all their lives.
And it very much depends on the regions of the world.
But could use Lisp or additional programs, and quickly solve everything. But they do not want.
I think this application with a minimum of settings to print drawings. It determines the number and format and orientation of the drawing the user only needs to configure the printer and plotter and send to print. Of course it should be interesting to those who have in one document or file is a lot of drawings (eg more than 100).
Of course the time to print drawings is still much less than their development.
Hi @john.vellek
How are you?
I read your post and I saw the video you made. I followed step by step but still cant success.
Can I send you my file so you can have a look of what Iam doing wrong?
This was really helpful and saved me a lot of time.
Had about 400 individual as-built .dwgs I just needed in a pdf binder. Sheet sizes were all the same, and lineweights weren't critical so a constant monochrome plot style was fine. Saved me a whole lot of tedium. Thank you!!
Plot panel
Page Setup.
Find
This option is available only for the Model tab.
