AutoCAD Forum
Any way you can change the dim style fit option distance?
4 REPLIES 4
ChengjieJiang
296 Views, 4 Replies
I wonder if you can change the distance for the leader with text so the leader don't touch the other dimension. also if i can make the dimension from top and bottom have the same distance.
4 REPLIES 4
pendean
in reply to: ChengjieJiang
Annotative dimstyle by chance?
ChengjieJiang
in reply to: pendean
The Dim Style is Already annotated
Kent1Cooper
DIMGAP affects the amount of offset there [when you don't reposition the text manually].  Why it comes out differently when above from when below, I don't know, but I think it does not if you have the text vertically centered on the dimension line, rather than above it.
Kent Cooper, AIA
pendean
Share a sample DWG file with your DIMSTYLE here please.
Forma Design Contest
