I wonder if you can change the distance for the leader with text so the leader don't touch the other dimension. also if i can make the dimension from top and bottom have the same distance.
DIMGAP affects the amount of offset there [when you don't reposition the text manually]. Why it comes out differently when above from when below, I don't know, but I think it does not if you have the text vertically centered on the dimension line, rather than above it.
@ChengjieJiang wrote:The Dim Style is Already annotated
Share a sample DWG file with your DIMSTYLE here please.
