AutoCAD Forum
3D drawing to laser cut machine
10 REPLIES 10
Message 1 of 11
2380 Views, 10 Replies
Hi everyone!
I struggle when I want to laser cut a 3D drawing out of one plastic sheet. For example I want to laser cut a chair with a seat surface and a back surface. When I want to laser cut this chair I can not only use the sizes of the two surface because I have to take the radius of the corner into account as well. Is there a fast way to do this in Autocad?
hope someone can help!
Labels (1)
10 REPLIES 10
Message 2 of 11
cheryl.buck
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Flattened 3D shapes can be complicated to work with. AutoCAD does not have a specific functionality for flattening complex objects, so curves like you describe generally would need to be accounted for manually.
You may find that the sheet metal functions in Inventor or Fusion 360 work well for this. They are able to calculate for radius' or bends. See this link for more information:
Autodesk Sheet Metal Software
Please let me know if this helps.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 11
dgorsman
What you're looking for is usually referred to as 'unfolding', rather than 'flattening' (projecting a 3D profile onto a plane as 2D geometry).  AutoCAD can do the latter but not the former.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 4 of 11
in reply to: cheryl.buck
Thirst of all, thanks for answering me!
I now have perhaps a more simple problem… When a costumer sends me an Autocad drawing of 3D, I want to convert that drawing into a 2D front view and a 2D top view. Is there a way in Autocad 2019 to do this fast? On YouTube there are only videos of older versions (2014 i.e.).
So how can I fix this in autocad 2019?
Thanks for helping me!
Message 5 of 11
vinodkl
You can use FLATSHOT to convert a 3D object to 2D object.
Here is how you can do that:https://www.youtube.com/watch?v=PlS5rgVKjz8
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 6 of 11
in reply to: vinodkl
Clarification of the problem, with a picture of how the customer sends the order. this product must be able to fit into the laser cutter, i.e. I need a 2D front view and a 2D top view. How can I do this easily in Autocad LT 2019 without having to re-draw it all over myself? I have tried to do things with view but nothing seems to work...
Please help me!
Thanks in advance!
Message 7 of 11
Clarification of the problem, with a picture of how the customer sends the order. this product must be able to fit into the laser cutter, i.e. i need a 2D front view and a 2D top view. How can I do this easily in Autocad LT 2019 without having to re-draw it all over myself?talboom.png
Please help me!
Thanks in advance!
Message 8 of 11
The customer has drawn a 3D drawing in a 2D file, so there is no z-axis only an x and y axis
Message 9 of 11
vinodkl
Aah, I see it now. Its a Isometric drawing.
Sorry, there is no shortcut to getting the front view and other views. You need to manually draw it by yourself.
Message 10 of 11
johnwilson58692
Step into a realm of radiant discounts and brilliant deals with "Shining Savings." Unveil the magic of exclusive 3D Laser Gifts coupons that bring a new glow to your shopping experience. This is your chance to illuminate your gift-giving with personalized laser-engraved treasures while enjoying remarkable savings.
Explore a curated selection of unique and heartfelt gifts, from elegantly etched crystal keepsakes to personalized ornaments that capture memories in intricate detail. With "Shining Savings," you're not just purchasing gifts; you're creating luminous moments that will be cherished forever.
Each coupon is your ticket to transforming ordinary occasions into extraordinary celebrations, all while enjoying unbeatable prices on these mesmerizing laser-engraved masterpieces. Whether it's a special anniversary, a cherished birthday, or a thoughtful gesture, "Shining Savings" lets you radiate affection without breaking the bank.
Elevate your gift-giving to a new level with 3D Laser Gifts' enchanting collection. Let your presents glow with the thoughtfulness that comes from choosing one-of-a-kind keepsakes. Don't miss out on this chance to brighten up your shopping experience while creating luminous memories with your loved ones. Discover the art of gift-giving that truly shines with "Shining Savings."
Enjoy the amazing deals and discount on 3d laser gifts coupons on coupontive.
Message 11 of 11
kinsleyaldous7
A successful affiliate marketing business is built on collaboration with reputable affiliate networks. Aparentlink has developed a comprehensive knowledge of the connected web environment and is ready to share that knowledge with you. Look for websites that offer accurate tracking, on-time payments, and reasonable invoices. With my advice, you’ll be ready to make smart choices about your network.
Technology Administrators
