Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I use autocad 2017 on a mac and I have a problem with the text on leaders.
A certain greek letter (π) appears as a number (as you can see in the screenshot).
I have changed many fonts and tried every text style from the drop down menu, but none of these seem to work.
Does anybody know how to fix this?
Thank you in andvance.
Solved by maxim_k. Go to Solution.
Hello!
I have macOS Mojave - version 10.14.6.
This problem appears with MTEXT and TEXT too.
On the screenshot below I have circled how the letter should appear (π). The arrows show how the letter appears after I save the file (it appears as the number 1).
I have this issue in other drawings as well.
In the attachment below there is a file with font problem.
As I wrote before, I don't have macOS and AutoCAD version you are using.
But I tested your drawing in 2016 version of AutoCAD for Mac (see attached) - look at the leaders in cyan color. Does they look correct on your Mac?
This is how they look on my side:
At what point does a letter π turn into a number?
When you type it or when you quit MTEXT editor?
