Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Port 80 Turned of by ISP
2 REPLIES 2
susan
382 Views, 2 Replies
Hi!  I recently changed Internet Service Providers and purchased my own cable modem/router rather than rent from the ISP.  After registering my cable modem/router with the ISP, I was not able to access AutoCAD or login to my AutoDESK account online.  I was able to access both from my home computer, which uses a different ISP, so I new my account was active.  The error messages I received indicated that it was a proxy server and/or firewall issue.
A have a single license and don't have an IT department.
As a first step I turned off my computer firewall and the router firewall (a bit scary), but that didn't correct the problem.  I then switched from a WIFI connection to Ethernet, and that didn't work.  I then spent a day and a half looking into remedies, including learning about proxy servers, where I saw that Port 80 and Port 443 were the ports the proxy servers needed to use.  I also noted that McAfee could cause issues for logging in, and knew that my ISP offered McAfee for free.  When I went to my ISP website to verify that McAfee had not been downloaded, I found that my ISP had turned off Port 80 and Port 25.  I turned on Port 80 and was then able to connect.
My question:  Does Port 80 have to be "on" to connect to AutoDESK and to access my account?  Was this the solution?  If so, would it make sense for AutoDESK to note that single user license holders should verify with their ISP that Port 80 is on?
If having Port 80 turned on was not the solution, does anyone have any suggestions?  I can't afford to not have access to AutoCAD from work!!!
Thank you in advance for any feedback.
Labels (1)
2 REPLIES 2
susan
in reply to: maxim_k
I’m using AutoCAD for MAC.  Thank you for forwarding the three links.  It looks like “Port numbers used by Autodesk Network License Manager” addresses the issue in the last line:  “On the client side, other ports can also be used. So make sure that on client side all ports are open for the communication with license server.”  As an architect and sole proprietor, I haven’t spent a lot of time researching the nuts and bolts of the internet.  Given that ISPs are known to turn off Port 80 and Port 25, I wonder if AutoDESK might dumb it down for the single user licenses and spell it out more clearly in the setup instructions.  In my initial search, I found the page, “Which URLs/Protocols need to be allowed for Autodesk Subscription Licensing,” but it doesn’t state clearly that on the client side all ports need to be open.  Had it been noted clearly at the top of the page that I should confirm with my ISP that all ports were open I would have saved a fair amount of time in my search.  Thank you again for your assistance.
