We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
"Can't offset that object"
Message 1 of 45
I'm having trouble offsetting some objects -- one minute the object will allow offsets, the next minute I get the message "can't offset that object."  I then have to redraw (and redraw...) the object until it eventually works (or not).
Anyone had this problem and have any solution?
Accepted solutions (3)
Replies (44)
Message 41 of 45
mdamirulfaiz.kalana
Thankss.the "OVERKILL" method works!
Message 42 of 45
simpletechdirect
what worked for me was to offset the poly line in the direction that it would allow and then offset it back in the direction I initially wanted.
Message 43 of 45
randall_frylandTF9DF
Observer
Observer
This still worked for me 11 years after your post. Thanks!
Message 44 of 45
s1251092
Community Visitor
Community Visitor
I try to offset the rectangle but it hard to offset so can you help me
Message 45 of 45
maxim_k
Hi @s1251092 ,
Did you turn off object snap before using OFFSET command?
Share your drawing here, maybe we will be able to help you.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
