Text along a curve using AutoCad for Mac 2025 not LT
Jeff_stockford
Observer Observer
Jeff_stockford
Observer
Observer
Is Arctext available in AutoCad for Mac 2025, if so how is it accessed? Also saw that it maybe in express tools are those included with the Mac version.
maxim_k
Hi @Jeff_stockford ,
There is no ARCTEXT command among the set of Express Tools in AutoCAD for Mac.
But you can try attached ARCTEXT.LSP to create text along an arc.
Use APPLOAD command to load this LSP and then use ARCTEXT command to create text along an arc.
Command: ARCTEXT
Give Character Height: 100
Give Arc/Circle Center Point: cen
of
Give Text Center Bottom Point:
Clockwise or Anticlockwise <C> :
Width Factor <1> :
Spacing Adjustment <0> :
Key Text: Test TEXT along ARC
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
josemyerramirez
Community Visitor
Community Visitor
saludos que puedo hacer si todavia no se soluciona el problema ?
Translated
Greetings, what can I do if the problem is still not solved?
maxim_k
Hi @josemyerramirez ,
In fact, the problem was solved by the community a year ago.
If you mean the ARCTEXT command is missing in Express Tools, then you need to contact >>>HERE<<< Look at the Autodesk Feedback Community.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
