"Can't offset that object"
Message 1 of 45
I'm having trouble offsetting some objects -- one minute the object will allow offsets, the next minute I get the message "can't offset that object."  I then have to redraw (and redraw...) the object until it eventually works (or not).
Anyone had this problem and have any solution?
Accepted solutions (3)
Replies (44)
Message 2 of 45
maxim_k
HI,
What kind of objects you try to offset? Is it Polyline, Spline or ...
And what do you mean by "redraw" object? Do you draw it from scratch?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 45
Thanks for your reply.
The most recent object that I was trying to offset was a polyline drawn with arc segments (~S-shaped polyline).  I haven't had trouble with splines.
Yes, by redraw I mean redrawing the object from scratch.
Message 4 of 45
maxim_k
OK,
If you (sorry, AutoCAD) can not offset polyline - please check at first that this polyline doesn't have zero-length segments, i.e. each vertex pair connected with non-zero length segment.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 45
Hi Maxim,
Thanks for your reply.  Can you give me more information on how I can tell if the polyline has zero-length segments?
Sarah
Message 6 of 45
maxim_k
Select polyline and walk trough the vertexes in Properties Inspector:
when you will see that after you change vertex number the white cross marker doesn't move - then it is the place of zero-length segment.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 45
Thanks for the clarification.
I have checked and there are no zero-length vertices in the object.
Some more observations about this situation --
I can offset the polyline on one side but not the other
I tried copying and pasting the polyline into a new file and it will offset
Message 8 of 45
margie_lo
I've had this same problem with offsetting polylines.  AutoCAD will not allow me to offset certain polylines.  When I try, it gives me the circle-slash symbol.  Have you had any luck finding a solution?
Message 9 of 45
maxim_k
I also have such issue sometimes, but despite the fact that AutoCAD shows prohibitory sign, it offsets polyline anyway.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 45
I just found a solution to your problem... first explode the polyline, then offset them one by one, then use the BO (Boundry Creation) command to convert them back to polylines... worked like a charm for me, I'm sure it'll work for you too!
Message 11 of 45
I used the "overkill" command. It deleted some segments and after that I was able to offset the polyline.
Message 12 of 45
3dwannab
Nice, thanks. Working solution. 10 years in AutoCAD and never experienced this.
Message 13 of 45
Thanks for the "OVERKILL" tip.
Message 14 of 45
Use command:- "OVERKILL" on the polyline.
Message 15 of 45
Did anyone ever figure out a way to sort this? Not sure what to do with the overkill command, Autodesk's knowledge centre recommends flattening the polyline (which doesn't work for me), so I'm still unable to even do this basic command.
Using AutoCAD 2014 for Windows.
Message 16 of 45
maxim_k
Could you describe in more details what kind of troubles do you have? Please attach drawing file if possible.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 45
ceethreedee.com
Overkill command is the business!!!
Civil 3D 2025 / Infraworks 2025
Win 10 -DELL Precision Notebook 7680
Want FREE TOOLS! Come get my free productivity tools for civil 3d from the appstore here Ceethreedee tools
Or from my website below!
https://ceethreedee.com/ceethreedee-tools
Message 18 of 45
Forgive me for resurrecting the dead but I found another solution.
In my case there wasn't anything wrong with the polyline; it just had too much concavity for the offset distance I wanted. The solution that worked for me was first offset it by the largest value I could get that wouldn't kick back an error. Then offset the offset by the remainder to get it the total offset distance. Testing this with different sets of offset distances gave the the same result.
Message 19 of 45
I had the same problem and i solved it this way; highlight the line/ open properties/ change vertex 'X' and 'Y' to '0'. then offset. (It worked for me).
Message 20 of 45
jlavoieQKYXY
Observer
Observer
Thank you. This worked 100%, I was trying to offset a line 1000m, no go. So like you suggested I tried a shorter distance, 100m. It worked!! So I just offset the line 10 times. 🙂 DONE!
ps. you da man!
