PDF underlay issues AutoCAD LT 2026
saheldt
saheldt
I recently upgraded to 2026 and until now I've been able to hide the pdf underlay by pressing the scroll wheel button on the mouse.  It doesn't work anymore and I can't find any solution for this.  It still works with a raster image.
When I have a pdf underlay on screen and highlight it, it hides the drawing even when draw order is set to back.  And lastly, when the pdf underlay snap is "off" everything snaps to a corner of the pdf.  Very annoying.
The only workaround I have is to convert all my pdf's to images and I don't want to have to do this.
Thanks in advance for any help!
maxim_k
Hi @saheldt ,
Yes, this is the standard behaviour with updated graphics engine.
BTW - images are also shows during pan or zoom if they were fully visible before panning began.
The same thing - standard behaviour.
Try to set PDFFRAME system variable to 0 (zero)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
saheldt
Thank you for your response and the tip to set pdfframe to 0.
I do have a question about your comment about me "not" being able to hide the pdf underlay with the scroll wheel button (pan).  Are you saying that it is correct that it does not work anymore?  Images still do hide when I pan with the current version as well as previous versions of LT for me.
Thanks!
maxim_k
Hi @saheldt ,
Yes. In 2026 version it works exactly the same as in AutoCAD for Windows for many years - PDF underlay is visible when you PAN the drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
saheldt
Hi @maxim_k,
Thanks for the clarification.  That's too bad it was a "feature" for me.
Thank you!
