AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
I'm having issues using subtract and erase functions. They were working fine previously.
10 REPLIES 10
Message 1 of 11
isaiahjprophete
620 Views, 10 Replies
Good morning,
I've just started training on AutoCAD Mac 2021 and was learning rather quickly but I'm having issues using subtract command to remove doors from a 3D model. Half of the doors removed using the function the remaining I utilized the erase (by face) function. One door is remaining and both functions won't work for some reason. I have attached the AutoCAD file and the door in question is toward the rear of the home. Any help is greatly appreciated.
Labels (2)
10 REPLIES 10
Message 2 of 11
maxim_k
in reply to: isaiahjprophete
Hi @isaiahjprophete ,
I had no problems with SUBTRACT command.
I drew a BOX with door dimensions and subtracted it from the main WALL solid.
See attached
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 11
isaiahjprophete
in reply to: maxim_k
I appreciate your help greatly. Could this be a change in my settings that caused the issue? I had removed the other doors and was working on another project. When I went back to the attach project (from original post) it wasn't working. What are some guidelines that allow successful subtraction each time... Thanks in advance.
Message 4 of 11
maxim_k
@isaiahjprophete ,
There are no special guidelines for subtraction except the SUBTRACT command workflow: you need at first select object from you want to subtract and hit Return, then you select object(s) you want to subtract. Of course, the objects should "intersect" in 3D space.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 11
maxim_k
@isaiahjprophete ,
I created section plane object and got a section of the wall.
I see the result of subtraction in your initial drawing:
But it is inside the wall and is not visible from outside. So the geometry you were using for subtraction had wrong dimensions - too small.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 11
isaiahjprophete
Thanks for finding my mistake. I'll do my best to adjust my skills.
Message 7 of 11
isaiahjprophete
Thank you in advance for your help.
Message 8 of 11
maxim_k
There was no problem with subtracting the right box from the wall as it has correct size and position.
I had to increase the height of the left box with central grip and move the whole box forward before subtracting it.
Look:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 11
maxim_k
Another way is to create holes in the wall with PRESSPULL command:
You need to create rectangles at first, then use PRESSPULL to cut the holes.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 11
isaiahjprophete
I appreciate your help I'm will try the pull command.
Message 11 of 11
maxim_k
You can read more about PRESSPULL in online Help:
https://help.autodesk.com/view/ACDMAC/2023/ENU/index.html?guid=GUID-9D072BB2-D97F-41DB-8414-41BC83A1...
https://help.autodesk.com/view/ACDMAC/2023/ENU/index.html?guid=GUID-C3C37B02-4063-4F25-98BD-2C470970...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
