maxim_k
en respuesta a: isaiahjprophete
@isaiahjprophete ,
There are no special guidelines for subtraction except the SUBTRACT command workflow: you need at first select object from you want to subtract and hit Return, then you select object(s) you want to subtract. Of course, the objects should "intersect" in 3D space.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
