Hi
AutoCAD LT 2020 for Mac trial won't run following upgrade to OS 10.14.6 (from 10.14.5)
I tried un-installing and re-installing, same problem.
When I launch the program I see the start of a menu bar at the top, then a window as if it's loading, then they disappear, that's it.
Can anyone help me get it working again please?
I am trying to see if LT will work for me as previously I had access to the full version. If I can complete my investigation I will buy a license.
Sorry, previously posted in the LT forum.
Maxim k
Hi, thanks for your response.
I previously tried a clean un-install. Same symptoms as oriniginally described - appears to load, then I see the coloured wheel of doom, then it all just vanishes.
I tried the hotfix as suggested, same result.
Any further help would be gratefully received.
I presume there is a missing / corrupt file or folder somewhere, but I've seen dire warnings from Autodesk that deleting certain files will mean that I will no longer be able to access the product - kind of where I am right now!
I'm in a catch 22 - unless I can confirm LT will work for me I obviously don't want to purchase it. Without a paid licence I have no access to Autodesk's tech support. Frustrating.
Thanks for your efforts though.
Maxim
Thanks for your suggestion.
I tried creating a new user account on my Mac and opening AutoCAD LT 2020 for Mac there, same result - I first see the start of a menu bar, then an AutoCAD window, then the coloured wheel, then they all disappear.
So, unfortunately I'm still stuck with my trial ticking down to zero with a system I can't use, with no way to access Tech Support.
Thanks for your suggestion though.
Sorted
I previously found alleged clean install instructions that gave dire warnings about deleting certain AutoCAD related files re not being able to access AutoCAD anymore if deleted - so obviously I left those alone.
Recently found a pukka clear set of instructions:
Did everything it suggested and re-installed AutoCAD - now it works, though my preferences have obviously been lost - a small price to pay.
I can get on with my trial, and hopefully purchase.
Thanks to all who responded.
BTW, that is what I suggested in my first response to your post HERE
So the solution is Clean reinstall.
