hi,
are anybody can convert this lisp to for mac?
Solved by maxim_k. Go to Solution.
Here it is, "converted" for Mac:
(defun c:PF (/ dd mm p1 p2 is nk1 nk2) (setq dd t) (setq mm 5) ;(setq obj (vlax-get-acad-object)) ;(setq doc (vla-get-ActiveDocument obj)) ;(setq ms (vla-get-ModelSpace doc)) (if (setq p1 (getpoint "\nFirstPoint:")) (progn (while dd (if (setq p2 (getpoint p1 "\nOtherPoint:")) (progn (setq ss (ssget "c" p2 p2)) (if ss (setq is -) (setq is +) ) (setq nk1 p1 nk2 (polar p1 (angle p1 p2) (is (distance p1 p2) mm)) ) ;(vla-addline ms (vlax-3d-point nk1) (vlax-3d-point nk2)) (command "LINE" nk1 nk2 "") (setq p1 nk2) ) (progn (setq dd nil) ) ) ) ) ) (princ) )
But I'm not sure this routine (even in "AC for Windows" variant) will give you results you need.
Thank you so much. Can we change this lisp a little?
If an object opposite of my direction that is working true but if nothing opposite of direction it is not working what I want. Can we can this for mouse actions to select offset side?
On my side the routine doesn't work correctly in any direction - it doesn't create lines parallel to existing with 5 units offset (red lines are the resulting lines):
Or I'm missing something?
