Autocad for mac lisp
bedyr
bedyr
hi,
are anybody can convert this lisp to for mac?
(defun c:PF (/ dd mm p1 p2 is nk1 nk2)
  (setq dd t)
  (setq mm 5)
  (setq obj (vlax-get-acad-object))
  (setq doc (vla-get-ActiveDocument obj))
  (setq ms (vla-get-ModelSpace doc))
  (if (setq p1 (getpoint "\nFirst Point:"))
    (progn
      (while dd
(if (setq p2 (getpoint p1 "\nOther Point:"))
 (progn
   (setq ss (ssget "c" p2 p2))
   (ifss
     (setq is -)
     (setq is +)
   (setq nk1 p1
 nk2 (polar p1 (angle p1 p2) (is (distance p1 p2) mm))
   (vla-addline ms (vlax-3d-point nk1) (vlax-3d-point nk2))
   (setq p1 nk2)
 (progn
   (setq dd nil)
  (princ)
0 Me gusta
Responder
Soluciones aceptadas (1)
749 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Solución aceptada
Here it is, "converted" for Mac:
  (setq dd t)
  (setq mm 5)
  ;(setq obj (vlax-get-acad-object))
  ;(setq doc (vla-get-ActiveDocument obj))
  ;(setq ms (vla-get-ModelSpace doc))
  (if (setq p1 (getpoint "\nFirstPoint:"))
    (progn
      (while dd
	(if (setq p2 (getpoint p1 "\nOtherPoint:"))
	  (progn
	    (if	ss
	      (setq is -)
	      (setq is +)
	    (setq nk1 p1
	    ;(vla-addline ms (vlax-3d-point nk1) (vlax-3d-point nk2))
	    (command "LINE" nk1 nk2 "")
	    (setq p1 nk2)
	  (progn
	    (setq dd nil)
  (princ)
But I'm not sure this routine (even in "AC for Windows" variant) will give you results you need.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
bedyr
Thank you so much. Can we change this lisp a little?
If an object opposite of my direction that is working true but if nothing opposite of direction it is not working what I want. Can we can this for mouse actions to select offset side?
0 Me gusta
maxim_k
On my side the routine doesn't work correctly in any direction - it doesn't create lines parallel to existing with 5 units offset (red lines are the resulting lines):
Or I'm missing something?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
bedyr
Can we change this for true direction?
0 Me gusta
