AutoCAD 2024, 2026 only half of screen viewport after macOS Tahoe
garett_rowe273
Message 1 of 48
garett_rowe273
It's always disappointing when a company the size of Autodesk doesn't do his job and test the widely announced newest macOS release. Months of time to correct any bugs, but still you choose to wait and see what happens.
UPDATE 09/26:
The solution proposed by @kclarkePZWHD is the most easier and elegant.
But it can be even simpler:
There’s no need to undock the Palettes or move the command line bar.
Just grab the right side of the command line bar (Picture 1)  and drag it to the end of the screen, passing behind the docked palettes (Picture 2).
Release and done.
Replies (47)
Message 21 of 48
kclarkePZWHD
I just had a Customer with this Issue If you
1. Undock the Pallets on the Right Side First, leave them Floating.
2. The Go to the Command Line and Dock the Command Line.
3. Stretch the Command Line the Whole Width of Model Space View Port
    you ordinarily required.
That Should Fix it.
IF possible then Save that "arrangement of tools" WorkSpace as My-Workspace.
This can be used as an emergency fall back position if you like or you can just persevere with it.
Message 22 of 48
kooshvyasarchitects
Community Visitor
Community Visitor
I also got same half screen issue and I tried your suggestion and it worked. Thank you.
Message 23 of 48
maxim_k
Hi @garett_rowe273 ,
The Update was released before Tahoe final release, that is why it doesn't resolve the problem.
We need to wait for a new Update.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 24 of 48
kclarkePZWHD
I must defend Autodesk in Fairness as a Partner. the Software AutoCAD 2026 for Mac was released prior to Tahoe. I dont think Apple Provided a Lot of notice on this OS release and it's arrived outside of Autodesk's "Standard Release Schedule" so they are re-engineering product to catch up. A Lot of vendors are I'd say. There is a new Graphics Engine to deal with.
You should be aware it does not state anywhere that AutoCAD or AutoCAD LT 2026 or other wise are supported on Tahoe.
(I'm not a MAC guy either however, I've seen this issue in the past in circa AutoCAD LT 2 or 3 and AutoCAD 13 when things were "weird" on Windows; not saying its old code or the interface is similar - its not - the stretched edge of dialog box is)
I can only say you could roll Tahoe back.??
Message 25 of 48
garett_rowe273
You are talking like Apple, one day decided to release a new version of their operating system without any warning....
The first developer beta of macOS Tahoe (version 26) was released on June 9, 2025. Tahoe was released to the public 4 months later.
If you are actively releasing and supporting Mac computers, is your duty as a software provider to test your own software in the widely announced and available betas.
Two updates were released way after the Tahoe beta availability:
2024.2.1 Update September 2, 2025
2026.0.1 Update August 5, 2025
And none of the them corrected the issues proactively.
And we are not talking about small UI issues, half of the screen is unusable...
Recommending users to stay lingering around in older versions of the macOS is not a good advice.
macOS Tahoe fixed over 70 security issues.
Autodesk needs to step-up its game and have a more dynamic and proactive release cycle of updates.
Message 26 of 48
juangalmez
Observer
Observer
it worked just one time, if I close and open the software again the problem persist
Message 27 of 48
kclarkePZWHD
I dont work for Autodesk I did say that.
You should Speak to YOUR channel Partner or Autodesk Support via your Autodesk Rep.
However Autodesk Will NOT certify Software ready for an Opperating system until its ready.
The development cycle may not allow for "Parachute implementation" of changes and new releases
to address features which were possibly in beta releases or possibly not.
I'm sure it will be along soon Unless the flexible edges of the pallets is a new MAC feature.
Message 28 of 48
maxim_k
AutoCAD for Mac 2026.1 Update has been released.
Along with many other fixes it fixes Properties, Layers, and Block palettes problem in macOS 26.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 29 of 48
kclarkePZWHD
Just 6 weeks behind the 2026.1 for PC that's excellent all things considered that August/September is Autodesk's Mid Term release date.
So all of the Software portfolio is updated tested and released in this period along with Cloud Platform updates and other things.
Kudos to the Development Teams.
Message 30 of 48
chiarialessia99
Observer
Observer
è normale che i file precedenti a questo aggiornamento abbiano mantenuto i problemi a differenza dei nuovi file creati dopo l'aggiornamento?
Solo a me nei vecchi file rimane il problema di non riuscire a tracciare le linee nei punti precisi dove voglio io?
Message 31 of 48
chiarialessia99
Observer
Observer
è normale che i file precedenti a questo aggiornamento riscontrino ancora problemi? Io ho notato che non riesco a tracciare la linea nel punto esatto in cui indico, ma dopo l'aggiornamento di oggi i nuovi file non sembrano aver problemi. Nei file vecchi il cursore farfalla e non posso lavorarci, invece i lavori creati dopo l'aggiornamento di oggi sembrano non aver problemi
Message 32 of 48
garett_rowe273
Thank you for the heads up!
Back to normal 😊
Message 33 of 48
maxim_k
Hi @chiarialessia99 ,
Please consider to start a new topic with your question.
Your question may get lost in this thread.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 34 of 48
nestorTGE
Community Visitor
Community Visitor
That worked. Thank you!
Message 35 of 48
paullimapa
Have you tried downloading & install AutoCAD / AutoCAD LT for Mac 2026.1 update?
Important AutoCAD for Mac Update information - 2026.1 - Autodesk Community
Paul Li
IT Specialist
@The Office
Message 36 of 48
fvega3ZY2R
Community Visitor
Community Visitor
This works for me...i updated from autocad 2025 to 2026 and the half screen disappear.
Maybe works, if you uninstall and reinstall the app (keeping the version)
Message 37 of 48
noejr
Community Visitor
Community Visitor
THANK YOU! This did the job for me!
Message 38 of 48
esonZSFT7
Community Visitor
Community Visitor
incredibly simple solution, Thank you so much
Message 39 of 48
julien_vittu
Community Visitor
Community Visitor
it doesn't work for me. the window immediately goes back to the cropped one, after dragging ...
Message 40 of 48
maxim_k
Hi @julien_vittu ,
Have you installed the updates for your AutoCAD version as described >>>>HERE<<<<?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
