I am trying to complete my panel wiring but am running into an issue with the terminal block annotations. If I try to annotate terminal block A1 in Panel 1, instead of just annotating what is connected to terminal block A1 in Panel 1, it is also showing what is connected to A1 in Panel 2, and Panel 3, and so on. INST and LOC are all set correctly. I thought it might be a copy/paste issue with data in the LINKTERM attribute, but that doesn't seem to be the case.
Solved by jcrispino3. Go to Solution.
If you think you might have a copy paste issue, check the xdata values of each terminal that is being treated the same using AEXDATA. Even though they may look different, if they have the same VIA_WD_HDL value, the software will think that they are the same part.
It ended up being a simple error/fix. I did not have the "Combined Installation/Location tag mode" selected under the Project Properties.
