AutoCAD Electrical Forum
Panel Terminal Block Annotation Showing Multiple Connections from Other Panels
3 REPLIES 3
jcrispino3
225 Views, 3 Replies
I am trying to complete my panel wiring but am running into an issue with the terminal block annotations. If I try to annotate terminal block A1 in Panel 1, instead of just annotating what is connected to terminal block A1 in Panel 1, it is also showing what is connected to A1 in Panel 2, and Panel 3, and so on. INST and LOC are all set correctly. I thought it might be a copy/paste issue with data in the LINKTERM attribute, but that doesn't seem to be the case.
3 REPLIES 3
Are you using the TSE to annotate your terminals?
testsubject
in reply to: jcrispino3
If you think you might have a copy paste issue, check the xdata values of each terminal that is being treated the same using AEXDATA. Even though they may look different, if they have the same VIA_WD_HDL value, the software will think that they are the same part.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
jcrispino3
It ended up being a simple error/fix. I did not have the "Combined Installation/Location tag mode" selected under the Project Properties.
Technology Administrators
