Hello all,
I have a large library of drawings for which I need to change the page setup setting "Plot Transparency" to true. All of these files use the same customized page setup of the same name for their one layout tab. I've found a method that uses the DWGCONVERT command to modify the page setups of many .dwg files at once, but this command does not update the current page setup assigned to the layout. I'd have to go through about a hundred individual drawings to update the page setups so that this dang ol' watermark will print.
Any way to make this process faster?
