AutoCAD Electrical Forum
Having problems with FULLFILENAME not showing on attributes within a Title Block
6 REPLIES 6
661 Views, 6 Replies
I'm currently trying to use AutoCAD Electrical to set up a mostly automatically updating title block for my company. I am using the <Project> .WDT File method for this block. I have about 23 attributes inserted and linked, and they're working fine, but the 24th is giving me issues. I have an attribute with a tag named FILE and I'm trying to link it to FULLFILENAME, but no matter what I do, after I update the title block in a drawing the attribute remains blank. Plotting the file doesn't do anything either. Is this something to do with the attribute name, or is it the drawing value that isn't working right? Thanks in advance,
Peter
6 REPLIES 6
rhesusminus
Those images doesn't really help much in trying to figure this one out. We'll just be guessing.
Any chance you can share the DWG (and/or wdt) ?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Here are the block .dwg and the test file I've been using, and the template. Unfortunately I can't upload the .wdt file, i'll try to post it as plain text.
.WDT:
BLOCK = TITLE BLOCK
DWGNO = DWGNAM
FILNAME = FULLFILENAME
SH = SHEET
SHTS = SHEETMAX
NAME = DWGSUB
TITLE1 = LINE1
TITLE2 = LINE2
TITLE3 = LINE3
PROJECT = LINE4
REV1 = LINE5
DRNBY1 = LINE6
DSNBY1 = LINE7
CHKBY1 = LINE8
REVDESC1 = LINE9
REV2 = LINE10
DRNBY2 = LINE11
DSNBY2 = LINE12
CHKBY2 = LINE13
REVDESC2 = LINE14
REV3 = LINE15
DRNBY3 = LINE16
DSNBY3 = LINE17
CHKBY3 = LINE18
REVDESC3 = LINE19
REV4 = LINE20
DRNBY4 = LINE21
DSNBY4 = LINE22
CHKBY4 = LINE23
REVDESC4 = LINE24
rhesusminus
The problem is that you've added the FILNAME attribute to the block later on. So.. it exists in the block DEFINITION, but not in the inserted block REFERENCE.
You can see this by double-clicking the title block, that the FILNAME attribute is missing.
Run the ATTSYNC command on the title block, and the attribute(s) should appear in the inserted block reference as well.
Trond Hasse Lie
Ctrl Alt El
ATTSYNC seems to have done it! Thank you. When I added that (and other) attributes in, I kept re-inserting the block to update the block definition, but I guess that went wrong at some point. Thanks again!
JeffatPrimex
Looking at your files I suspect your drawing database is corrupted some how. The fix is to open a new file from a clean template like acad.wdt then copy and paste in your drawing geometry and text. IMO you should purge all unnecessary blocks first.
Best regards,
 Jeff
