AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Recessed Niche in Wall Component
4 REPLIES 4
847 Views, 4 Replies
Wondering what the best way is to place a recessed niche in a Wall component? I can somewhat get the desired effect drawing a 4" or 6" wall with a 2" thick (furring) wall butted up together but it seems that I need to have the justifications all on the same side of the walls in order for it to clean up properly.
Is it possible to create/use a wall opening that has a certain depth (such as 2 or 4) and that will anchor to one side of the desired wall.
Thanks!
4 REPLIES 4
David_W_Koch
Yes, it is possible.
One way would be to create a Mass Element representing the void you want to create, and to use that as an interference condition with the Wall.  Freeze the layer on which the Mass Element is placed, and you get a niche cut into your Wall.2019-05-30_ACA2020_MassElementInterference_NicheInWall.png
The sample file attached was done in ACA 2020 (AutoCAD 2018 file format).
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
brian_adams
other one method that @David_W_Koch  havn't mention is useing chases
from designe center,also via interference condition
But it has only rectangular outlines
brian_adams
just reminde to my self one more method
glue together  two walls
draw two walls side to side , and via  select wall\wall context menu>Cleanupc> Add wall merge condition
in plan view it will looks like single wall but it two
Then add opening to the one of them
R_Tweed
in reply to: David_W_Koch
Just an add-on note. You can use a mass element or solid as a body modifier. Then you wouldn't  need to freeze anything. Body modifiers can be edited like mass elements in place, moved etc.
Robert
Forma Design Contest
AutoCAD Beta
