Hi!
I created multi-view blocks reference with some transparency.
Why is the result difference in created pdf file and view realm of autocad?
The problem file is attached.
I have not checked your attached file but one possibility occurs to me......in the plot dialog box did you check the box for "plot transparency"?
No, it is turned on if I right understand. If it had turned off you did not see any transparent objects on my screenshots.
