AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
More resolution to railing - spiral stair and circular base columns
2 REPLIES 2
Richard.Vivanco
412 Views, 2 Replies
Hi
I tried to add more resolution to railings in spiral stair and to circular base columns (i use the structural member wizard)
Facetdev with small values works fine in other objects (circular hole and stair) but not in the other two objects
Any suggestions?
Thanks.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
2 REPLIES 2
dbroad
in reply to: Richard.Vivanco
Post your dwg file.  It's probably because you don't have any balasters.  That might be confusing the railing object.
Architect, Registered NC, VA, SC, & GA.
Richard.Vivanco
in reply to: dbroad
Thanks again! as you said,  the problem was the balasters
Richard Vivanco V.
Technology Administrators
AutoCAD Beta
