AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Sheet Set Manager Issue - Publish in Background without Prompt for PDF Name
1 REPLY 1
skultan172
627 Views, 1 Reply
skultan172
Software Version: AutoCAD Architecture 2018
I've spent way to much time trying to figure this out, so I'm turning to the forums hoping that someone a little more experience then I has some insight.
Here is what I'm trying to do, and what AutoCAD is doing instead.
Goal - Using the Sheet Set Manager (Publish using Page Setup Override Setting), publish a set of sheets IN THE BACKGROUND and SPECIFYING FILE NAME before publishing (IE - no prompt for file name).
Issue - Despite telling AutoCAD to NOT prompt for name, and having "Publish in Background" on, AutoCAD still prompts me for a PDF name, and then publishes in the FOREGROUND 😤
Here is a video trying to showcase all the options I have set and the method I've been going through. Does anyone have any ideas on settings I may have missed.
1 REPLY 1
skultan172
in reply to: skultan172
skultan172
Got it figure out - I just had to update my Adobe printer settings to not prompt for file name - it turns out it wasn't AutoCAD causing the issue at all.
