ADD COLUMNS TO GRID
ADD COLUMNS TO GRID
Richard.Vivanco
Advisor Advisor
Message 1 of 8
ADD COLUMNS TO GRID
Richard.Vivanco
Hi
Exists an option to add a set of columns directly to the grid instead one by one?
Similar to like revit does.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Replies (7)
Message 2 of 8
David_W_Koch
If you press Ctrl and click when adding a Column to a a Grid,it will be added to all nodes.  See the full procedure here:  https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2... .
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 3 of 8
Richard.Vivanco
I tried the method but it doesnt work.
Richard Vivanco V.
Message 4 of 8
David_W_Koch
My apologies; I am at AU this week and do not have access to a computer running AutoCAD Architecture to try it out for myself. Perhaps someone else can try itand report if they have the same results as you. I recall being able to copy a column to all open nodes of a grid, but have not done so in a while.
David Koch
Blog | LinkedIn
Message 5 of 8
dbroad
David is correct. Turn your tool tips on and hover over the grid while adding a column for hints. You may have to tap the CTRL key a couple of times to cycle to the mode you desire.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 8
Richard.Vivanco
Thanks, i will keep trying.
In theory its possible, but perhaps my procedure is incorrect.
Richard Vivanco V.
Message 7 of 8
Richard.Vivanco
Thanks to both of you, I can finally do it! I forgot to drag and open a window selection after pressing CTRL
Richard Vivanco V.
Message 8 of 8
dbroad
That is only one mode.  Two CTRL taps allows you to add columns everywhere.
