Hi
I tried to add more resolution to railings in spiral stair and to circular base columns (i use the structural member wizard)
Facetdev with small values works fine in other objects (circular hole and stair) but not in the other two objects
Any suggestions?
Thanks.
Solved by dbroad. Go to Solution.
Post your dwg file. It's probably because you don't have any balasters. That might be confusing the railing object.
