AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
FATAL ERROR: Unhandled Delayload
4 REPLIES 4
jeff
7676 Views, 4 Replies
I am getting the following when trying to open certain files;
 FATAL ERROR: Unhandled Delayload "modlr23.dll" Module Not Found Exception at FD66A06Dh.
I have uninstalled and re-installed the program.  I have done multiple system re-starts.
Any thoughts would be most appreciated!
USERNAME for clarity Kevin.Palmer edited the original subject: FATAL ERROR code
4 REPLIES 4
pendean
in reply to: jeff
Fix the files, here i a list of the dozen ways to do that (no one method works all the time) https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Kevin.Palmer
in reply to: jeff
Hi @jeff,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
In addition to @pendean's suggestion, I would also ask what version of AutoCAD Architecture you are working in, and if you are fully updated?
Kevin.Palmer
in reply to: jeff
Hi @jeff,
I'm just checking in to see if you need more help with this. Did the suggestions that @pendean and I provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
jeff
in reply to: Kevin.Palmer
REPLY
We actually installed the update that was available and that cleared the
problem
Technology Administrators
AutoCAD Beta
