AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
3D sloped curve
9 REPLIES 9
Message 1 of 10
1304 Views, 9 Replies
3D sloped curve
Hi all !
I have been using autocad for a long time. These days I have to produce a 3D plan that I do very rarely. Usually, I'm doing pretty well. For the current project, I can not imagine how to draw in 3D a curve that is to be sloping. See my attached drawing. This is a small path between the house and the sidewalk . There is a 24 "slope between the beginning and the end.
Please help me !
Thanks in advance !
9 REPLIES 9
Message 2 of 10
brian_adams
you better change UCS  - make new one , that sloped between two planes
Currently in my example I used by 3 point.
Message 3 of 10
in reply to: brian_adams
Thank you so much Brian !
Another question !
Is it normal, as soon I change the view, I lost the UCS I setted ?
Message 4 of 10
brian_adams
Yes? but you can save this view like standard"top","bottom" etc/and can back to it view when you wish
simply after you have changed the view rename it and it appears in standard views3к3.jpg
Message 5 of 10
Hi Brian !
Me again Smiley Wink
With your technique, I can draw in the right UCS, but I cant reproduce the same thing as my sample (DWG). I would appreciate that you demonstrate it to me like this morning with a small GIF.
Thank you very much in advance !
Message 6 of 10
brian_adams
You mean you can't follow your line-work?
check " Replace Z value with current elevation"
Message 7 of 10
brian_adams
Some minutes after posting I have got, you want exactly projection of line to the sloped plane . well I cant do it very fine but result pretty well
In this case changing of UCS in viewport not necessary
you need only to change EXACT ucs!
in gif I forgot to check" replace Z value" after I have changed UCS - it is better to check
plane3.gifi
Message 8 of 10
Hi Brian !
As per your last GIF, I got the same thing as I follow the first one...
Is it normal that the curved polyline is snapped on my linework below, check my drawing please...
Thanks again !
Message 9 of 10
...or with this version, the island is not snapped on the same level, when you check in the left view
Thanks !
Message 10 of 10
brian_adams
this happened because you don't turn on " replace Z value with current elevation"
just turn it on after you changed UCS and the problem gone away !!
" replace Z value with current elevation" it is like snape to plane of UCS
If you try to change UCS with turning on "replace Z value with current elevation" you trying  will definitely fault
also turn OFF 3D snap
use just 2d snap
Technology Administrators
AutoCAD Beta
