I am getting the following when trying to open certain files;
FATAL ERROR: Unhandled Delayload "modlr23.dll" Module Not Found Exception at FD66A06Dh.
I have uninstalled and re-installed the program. I have done multiple system re-starts.
Any thoughts would be most appreciated!
USERNAME for clarity Kevin.Palmer edited the original subject: FATAL ERROR code
Solved by jeff. Go to Solution.
Hi @jeff,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
In addition to @pendean's suggestion, I would also ask what version of AutoCAD Architecture you are working in, and if you are fully updated?
Hi @jeff,
Hi @jeff,
I'm just checking in to see if you need more help with this. Did the suggestions that @pendean and I provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi @jeff,
