Transferred 2015 to a new Windows 10 laptop. Finally got my cui, toolbars and everything working like I wanted. Now my wall, doors, etc. are showing as AEC items. I can't select them or do anything with them.
Anyone have any advice?
USERNAME for clarity VStudley edited the original subject: Transfer to new laptop Architecture 2015
Solved by Victoria.Studley. Go to Solution.
Solved by pendean. Go to Solution.
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
You may want to try the suggestions in this article to narrow down what's happening: Missing MEP or Architecture tools in AutoCAD MEP or AutoCAD Architecture
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestions that @pendean or I provided last week help you get to the bottom of this?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
