AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Cannot change X-ref drawing colors
2 REPLIES 2
Renee_Ve
245 Views, 2 Replies
I have floorplan I want to use as a grey background.
In one drawing I succeeded in putting the background x-ref on grey (253)
In the other drawing I get mulitple blocks , walls and annotation that does not want to turn grey, and I don't know why.
In both cases I just use override in the layermananger and put all the layers on grey.
Does anyone know the setting I should use to make the entire x-ref grey?
I hope you have an idea to solve this problem!
2 REPLIES 2
pendean
in reply to: Renee_Ve
Look up XREFOVERRIDE in HELP in the program and see if that is an option for you with your files.
Renee_Ve
in reply to: pendean
Thanks put XREFOVERRIDE from 0 to 1 and it worked!
Forma Design Contest
