I have floorplan I want to use as a grey background.
In one drawing I succeeded in putting the background x-ref on grey (253)
In the other drawing I get mulitple blocks , walls and annotation that does not want to turn grey, and I don't know why.
In both cases I just use override in the layermananger and put all the layers on grey.
Does anyone know the setting I should use to make the entire x-ref grey?
I hope you have an idea to solve this problem!
Solved by Renee_Ve. Go to Solution.
Solved by pendean. Go to Solution.
