- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Probably what the Noice Denoiser imager is doing..
collecting samples from buckets, process them, filter and display them back from driver_close at the end.
This works already flawlessly with a raw driver.
But beside it doesn't look it's able to use a callback from driver_close (so I have to write down an image), it's not called at all from the IPR or it simply crashes if plugged as an imager because it looks anything there is a display driver.
On the other side if from a display driver I try to collect samples.. Arnold crashes.
So let's start easy...
Is it clear what I'm asking ? To collect samples from buckets, process and display them when rendering is finished.
Is it possible at all with what we have from the Arnold SDK ?
