Does a polymesh node require a matrix? Geometry in question is baked but does it still need an identity matrix?
'kick -info' for polymesh node shows:
MATRIX[] matrix (empty)
Render log shows:
WARNING | <name of polymesh>: shape has degenerate (non-invertible) matrix transform
Using version 5.1.0.1
Thank you!
Render log:
Thanks!
Stephen.Blair
If I delete the matrix from an ass file and kick the ass file, I don't get that WARNING.
Same if I put matrix NULL
What do you have for the matrix?
// Stephen Blair
// Arnold Renderer Support
Since the geometry is baked, a matrix is not specified in the assfile, so it would fall back to the node's default for that param.
Thank you,
