Arnold General Rendering Forum
why Arnold 3.2 Cpu is working 10 times slower than previous release?
7 ANTWORTEN 7
Nachricht 1 von 8
618 Aufrufe, 7 Antworten
Hi, im having this issue.
the Same scene is rendering 10 times slower than the previous version . Same final quality. No skydome.
changed the sss mode back to diffusion (but it wasn't making any difference)
Even AA sampling in 1 and everything else in 0 takes to much time for the result it shows.
Any ideas?
im downgrading for the moment. in this condition it is not viable to work with
thanks!
7 ANTWORTEN 7
Nachricht 2 von 8
thiago.ize
als Antwort auf: Anonymous
Can you enable verbose logs and render with both versions? That should hopefully give an indication of what's going on.
Nachricht 3 von 8
teddude75
Look at your thread count at render time. In Arnold 3.2 I get 80% of my threads going and turning off auto detect threads helps.
Nachricht 4 von 8
Slava_91
what SSS mode you use in 3.2 and 2.0?
Nachricht 5 von 8
The mode changes automatically from diffusion to randomwalk. ive changed back to diffusion though and the changes in render time are very small
is not a sss problem. the hair takes for ever to render
Nachricht 6 von 8
lee_griggs
Are you using Extra Samples? What are your Ray Depth and Light sample settings?
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 7 von 8
Slava_91
Yes I see same problem in work scene without sss, but in seconds slower
3min per frame on 5.2 core and 3.5min per frame on 3.2 core
Nachricht 8 von 8
Stephen.Blair
It's hard to tell what's going without some logs, or a scene.
It's xgen hair, right? Is the slowdown in the actual rendering or in scene initialization?
// Stephen Blair
// Arnold Renderer Support
