I'm creating some UserParameters, and trying to pass them as arguments during creation of various shapes and features. When passing them, I use ValueInput.createByString("nameOfParameter"). This isn't working (error messages below). It works in the GUI. Here's my code:
import adsk.core, adsk.fusion, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface product = app.activeProduct design = adsk.fusion.Design.cast(product) # Get the root component of the active design rootComp = design.rootComponent #defining userParams userParams = design.userParameters userParams.add("strawDia", adsk.core.ValueInput.createByString("10 mm"), "mm", "") userParams.add("noOfPegs", adsk.core.ValueInput.createByString("3"), "", "") origin = adsk.core.Point3D.create(0, 0, 0) #first sketch, central hub hubSketch = rootComp.sketches.add(rootComp.xYConstructionPlane) hubCircles = hubSketch.sketchCurves.sketchCircles hubCircles.addByCenterRadius(origin, adsk.core.ValueInput.createByString("strawDia")) #uMag = adsk.core.UnitsManager #print(uMag.isValidExpression("strawDia*2", "mm")) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
To see if it was getting evaluated correctly, I tried to use evaluateExpression and isValidExpression, but it always tells me I have the wrong type/number of arguments despite me adhering to the specification in the documentation.
I cannot use any of the ValueInput creation methods, not even createByReal. Only sending an actual double seems to work.
Could I pointed to what I'm missing?
Solved by JeromeBriot. Go to Solution.
Try this :
hubCircles.addByCenterRadius(origin, userParams.itemByName("strawDia").value)
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Okay, this works, but now if I change the value of strawDia under 'Change User Parameters', the model doesn't update automatically. How do I pass strawDia such that anytime it is modified, the whole model is recomputed and redrawn, just like in the GUI? Or in C++ parlance, how do I pass by reference and not by value?
ui.commandDefinitions.itemById('FusionComputeAllCommand').execute()
is your friend to force a recmputation
Add a dimension and link it to the parameter:
origin.x = 1.0 dim = hubSketch.sketchDimensions.addDiameterDimension(hubCircles.item(0), origin) dim.parameter.expression = "strawDia"
And as you specify diameter instead of radius, my previous answer should be:
hubCircles.addByCenterRadius(origin, 0.5*userParams.itemByName("strawDia").value)
This seems to be workable.
But why do you change the x-coordinate of origin? Without it, I get an error saying input argument is invalid. What is the text point/dimension text mentioned in the docs?
Also, after using your code, the circle becomes of size strawDia, while I've assigned the expression "strawDia*2* to it.
swagath.sivakumar a écrit :But why do you change the x-coordinate of origin? Without it, I get an error saying input argument is invalid. What is the text point/dimension text mentioned in the docs?
To add diameter dimension, you need to specify a point that is not the origin of the circle. Read this thread : Possible bug in addDiameterDimension
swagath.sivakumar a écrit :Also, after using your code, the circle becomes of size strawDia, while I've assigned the expression "strawDia*2* to it.
Sorry but I don't understant what you mean.
What value is represented by strawDia ? A diameter or a radius ?
strawDia is a diameter, but the component I'm creating is not the straw. So all the measurements for this component are proportional to what the straw diameter will be.
Anyway, thank you for the tip regarding dimensions. The cylinder radii in my model are now completely parametric. Any idea how I can do the same for pattern arguments? Right now, I'm passing a user parameter's value for the countU of a pattern like so:
userParams = design.userParameters userParams.add("noOfPegs", adsk.core.ValueInput.createByString("3"), "", "") noOfPegs = userParams.itemByName("noOfPegs") circularFeats = rootComp.features.circularPatternFeatures circularFeatInput = circularFeats.createInput(inputEntities, zAxis) circularFeatInput.quantity = adsk.core.ValueInput.createByReal(noOfPegs.value) #<------------------------------- here circularFeatInput.totalAndle = adsk.core.ValueInput.createByString('360 deg') circularFeat = circularFeats.add(circularFeatInput)
I'm also wanting to use strawDia similarly to set some extrude distances:
#make circle for profile, create extrude input, blah blah extrusionInput.setDistanceExtent(True, adsk.core.ValueInput.createByReal(strawDia.value*1.5)) extrusion = extrudes.add(extrusionInput)
I need the measurements to automatically update whenever strawDia changes. Solving this would completely solve my doubt. And thank you, you've been really helpful so far!
You can deal with the ModelParameters collection.
I modified the CircularPattern feature API sample available here
import adsk.core, adsk.fusion, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface # Create a document. doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType) product = app.activeProduct design = adsk.fusion.Design.cast(product) # Define user parameters userParams = design.userParameters if userParams.itemByName("strawDia"): userParams.itemByName("strawDia").deleteMe() if userParams.itemByName("noOfPegs"): userParams.itemByName("noOfPegs").deleteMe() userParams.add("strawDia", adsk.core.ValueInput.createByString("10 mm"), "mm", "") userParams.add("noOfPegs", adsk.core.ValueInput.createByString("3"), "", "") # Get the root component of the active design. rootComp = design.rootComponent # Create sketch sketches = rootComp.sketches sketch = sketches.add(rootComp.xZConstructionPlane) sketchCircles = sketch.sketchCurves.sketchCircles centerPoint = adsk.core.Point3D.create(10, 0, 0) circle = sketchCircles.addByCenterRadius(centerPoint, userParams.itemByName("strawDia").value) centerPoint.x = 1.0 dim = sketch.sketchDimensions.addDiameterDimension(sketchCircles.item(0), centerPoint) dim.parameter.expression = "strawDia" # Get the profile defined by the circle. prof = sketch.profiles.item(0) # Create an extrusion input extrudes = rootComp.features.extrudeFeatures extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation) # Define that the extent is a distance extent of 5 cm. distance = adsk.core.ValueInput.createByReal(5) extInput.setDistanceExtent(False, distance) # Create the extrusion. ext = extrudes.add(extInput) # Get the body created by extrusion body = rootComp.bRepBodies.item(0) # Create input entities for circular pattern inputEntites = adsk.core.ObjectCollection.create() inputEntites.add(body) # Get Y axis for circular pattern yAxis = rootComp.yConstructionAxis # Create the input for circular pattern circularFeats = rootComp.features.circularPatternFeatures circularFeatInput = circularFeats.createInput(inputEntites, yAxis) # Set the quantity of the elements circularFeatInput.quantity = adsk.core.ValueInput.createByReal(userParams.itemByName("noOfPegs").value) # Set the angle of the circular pattern circularFeatInput.totalAngle = adsk.core.ValueInput.createByString('180 deg') # Set symmetry of the circular pattern circularFeatInput.isSymmetric = False # Create the circular pattern circularFeat = circularFeats.add(circularFeatInput) # Link feature properties withg user parameters for param in rootComp.modelParameters: if param.role=="AlongDistance": param.expression = "1.5*strawDia" if param.role=="countU": param.expression = "noOfPegs" except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It's up to you to find the correct parameter in the modelParameters list.
I checked the role property in the code above but it could be different in more complex model.
Here's a version of your original program that I believe does what you want.
import adsk.core, adsk.fusion, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface product = app.activeProduct design = adsk.fusion.Design.cast(product) # Get the root component of the active design rootComp = design.rootComponent #defining userParams userParams = design.userParameters param = userParams.add("strawDia", adsk.core.ValueInput.createByString("10 mm"), "mm", "") diaValue = param.value userParams.add("noOfPegs", adsk.core.ValueInput.createByString("3"), "", "") origin = adsk.core.Point3D.create(0, 0, 0) hubSketch = rootComp.sketches.add(rootComp.xYConstructionPlane) # Draw the circle. hubCircles = hubSketch.sketchCurves.sketchCircles circle = hubCircles.addByCenterRadius(origin, diaValue/2) # Add a dimnension constraint to control the size. dims = hubSketch.sketchDimensions txtPnt = adsk.core.Point3D.create(origin.x + diaValue*.5, origin.y + diaValue*.5, 0) diaDim = dims.addDiameterDimension(circle, txtPnt, True) diaDim.parameter.expression = param.name except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
