- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am not sure, but there may be a bug in addDiameterDimension. It seems to be inconsistent on weather or not it adds a dimension in the sketch that the user can interact with based on where you put the txtPoint. If you make a circle by center and radius and then put the txtPoint at the center, it won't add it in the sketch. However, it will end up in the model parameters.
Not sure if there is some kind of logic that determines if it shows up in the sketch, but I would think that it should show up all the time. If there is some logic, could you let me know it is?
21st Century Woodworking
-Blending 21st Century Woodworking with Old World Skill
