Trouble passing ValueInput as argument to features
I'm creating some UserParameters, and trying to pass them as arguments during creation of various shapes and features. When passing them, I use ValueInput.createByString("nameOfParameter"). This isn't working (error messages below). It works in the GUI. Here's my code:
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        # Get the root component of the active design
        rootComp = design.rootComponent
        #defining userParams
        userParams = design.userParameters
        userParams.add("strawDia", adsk.core.ValueInput.createByString("10 mm"), "mm", "")
        userParams.add("noOfPegs", adsk.core.ValueInput.createByString("3"), "", "")
        origin = adsk.core.Point3D.create(0, 0, 0)
        #first sketch, central hub
        hubSketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
        hubCircles = hubSketch.sketchCurves.sketchCircles
        hubCircles.addByCenterRadius(origin, adsk.core.ValueInput.createByString("strawDia"))
        #uMag = adsk.core.UnitsManager
        #print(uMag.isValidExpression("strawDia*2", "mm"))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
To see if it was getting evaluated correctly, I tried to use evaluateExpression and isValidExpression, but it always tells me I have the wrong type/number of arguments despite me adhering to the specification in the documentation.
I cannot use any of the ValueInput creation methods, not even createByReal. Only sending an actual double seems to work.
Could I pointed to what I'm missing?
Replies (9)
JeromeBriot
Try this :
hubCircles.addByCenterRadius(origin, userParams.itemByName("strawDia").value)
Okay, this works, but now if I change the value of strawDia under 'Change User Parameters', the model doesn't update automatically. How do I pass strawDia such that anytime it is modified, the whole model is recomputed and redrawn, just like in the GUI? Or in C++ parlance, how do I pass by reference and not by value?
designingberlin
ui.commandDefinitions.itemById('FusionComputeAllCommand').execute()
is your friend to force a recmputation
JeromeBriot
Add a dimension and link it to the parameter:
        origin.x = 1.0
        dim = hubSketch.sketchDimensions.addDiameterDimension(hubCircles.item(0), origin)
        dim.parameter.expression = "strawDia"
And as you specify diameter instead of radius, my previous answer should be:
hubCircles.addByCenterRadius(origin, 0.5*userParams.itemByName("strawDia").value)
This seems to be workable.
But why do you change the x-coordinate of origin? Without it, I get an error saying input argument is invalid. What is the text point/dimension text mentioned in the docs?
Also, after using your code, the circle becomes of size strawDia, while I've assigned the expression "strawDia*2* to it.
JeromeBriot
To add diameter dimension, you need to specify a point that is not the origin of the circle. Read this thread : Possible bug in addDiameterDimension
Sorry but I don't understant what you mean.
What value is represented by strawDia ? A diameter or a radius ?
strawDia is a diameter, but the component I'm creating is not the straw. So all the measurements for this component are proportional to what the straw diameter will be.
Anyway, thank you for the tip regarding dimensions. The cylinder radii in my model are now completely parametric. Any idea how I can do the same for pattern arguments? Right now, I'm passing a user parameter's value for the countU of a pattern like so:
noOfPegs = userParams.itemByName("noOfPegs")
circularFeats = rootComp.features.circularPatternFeatures
circularFeatInput = circularFeats.createInput(inputEntities, zAxis)
circularFeatInput.quantity = adsk.core.ValueInput.createByReal(noOfPegs.value) #<------------------------------- here
circularFeatInput.totalAndle = adsk.core.ValueInput.createByString('360 deg')
circularFeat = circularFeats.add(circularFeatInput)
I'm also wanting to use strawDia similarly to set some extrude distances:
#make circle for profile, create extrude input, blah blah
extrusionInput.setDistanceExtent(True, adsk.core.ValueInput.createByReal(strawDia.value*1.5))
extrusion = extrudes.add(extrusionInput)
I need the measurements to automatically update whenever strawDia changes. Solving this would completely solve my doubt. And thank you, you've been really helpful so far!
JeromeBriot
You can deal with the ModelParameters collection.
I modified the CircularPattern feature API sample available here
def run(context):
    ui = None
    try:
        # Create a document.
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        # Define user parameters
        if userParams.itemByName("strawDia"):
            userParams.itemByName("strawDia").deleteMe()
        if userParams.itemByName("noOfPegs"):
            userParams.itemByName("noOfPegs").deleteMe()
        # Get the root component of the active design.
        # Create sketch
        sketches = rootComp.sketches
        sketch = sketches.add(rootComp.xZConstructionPlane)
        sketchCircles = sketch.sketchCurves.sketchCircles
        centerPoint = adsk.core.Point3D.create(10, 0, 0)
        circle = sketchCircles.addByCenterRadius(centerPoint, userParams.itemByName("strawDia").value)
        centerPoint.x = 1.0
        dim = sketch.sketchDimensions.addDiameterDimension(sketchCircles.item(0), centerPoint)
        # Get the profile defined by the circle.
        prof = sketch.profiles.item(0)
        # Create an extrusion input
        extrudes = rootComp.features.extrudeFeatures
        extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        # Define that the extent is a distance extent of 5 cm.
        distance = adsk.core.ValueInput.createByReal(5)
        extInput.setDistanceExtent(False, distance)
        # Create the extrusion.
        ext = extrudes.add(extInput)
        # Get the body created by extrusion
        body = rootComp.bRepBodies.item(0)
        # Create input entities for circular pattern
        inputEntites = adsk.core.ObjectCollection.create()
        inputEntites.add(body)
        # Get Y axis for circular pattern
        yAxis = rootComp.yConstructionAxis
        # Create the input for circular pattern
        circularFeatInput = circularFeats.createInput(inputEntites, yAxis)
        # Set the quantity of the elements
        circularFeatInput.quantity = adsk.core.ValueInput.createByReal(userParams.itemByName("noOfPegs").value)
        # Set the angle of the circular pattern
        circularFeatInput.totalAngle = adsk.core.ValueInput.createByString('180 deg')
        # Set symmetry of the circular pattern
        circularFeatInput.isSymmetric = False
        # Create the circular pattern
        # Link feature properties withg user parameters
        for param in rootComp.modelParameters:
            if param.role=="AlongDistance":
                param.expression = "1.5*strawDia"
            if param.role=="countU":
                param.expression = "noOfPegs"
    except:
        if ui:
It's up to you to find the correct parameter in the modelParameters list.
I checked the role property in the code above but it could be different in more complex model.
ekinsb
Here's a version of your original program that I believe does what you want.
def run(context):
    ui = None
    try:
        param = userParams.add("strawDia", adsk.core.ValueInput.createByString("10 mm"), "mm", "")
        diaValue = param.value
        # Draw the circle.
        circle = hubCircles.addByCenterRadius(origin, diaValue/2)
        # Add a dimnension constraint to control the size.
        dims = hubSketch.sketchDimensions
        txtPnt = adsk.core.Point3D.create(origin.x + diaValue*.5, origin.y + diaValue*.5, 0)
        diaDim = dims.addDiameterDimension(circle, txtPnt, True)
        diaDim.parameter.expression = param.name
    except:
        if ui:
Brian Ekins
Mod the Machine blog
