Get back Block Editing in place for AS2017
In AS2017 block editing in pace is eliminated, this is the tech. support responce:
'This feature was intentionally removed in AS 2017. It was shared for both blocks and xrefs, and we were unfortunately limited in using the AutoCAD functionality in our code.
The decision to remove it was to avoid dwg corruption that would occur when using edit in place, especially for xrefs.'
Please get back block editing in place in Advance Steel, we are using it on a daily basis, or give as an option to turn on or off, and make off by default if this is more reasonable for some users.
Ilko Dimitrov
4 Comments
haedicu
Drawtech
I strongly agree - we need this back ASAP.
Often blocks for "Special Parts" need to be modified - e.g. the angle of a hinged part or similar.  To have to do this outside the model or to explode and recreate the block is a major inconvenience.
Also another major issue with this is Protoype drawings.
I work for many different clients and to configure new prototypes, I always used to edit the HYPERSTEELPAGEHEADER block for the title block in place to change the company logo etc.
I cannot do this now, which costs so much more time.
I strongly agree too !
Command can be disabled for Xref only using command reactors...
haedicu
