Can there be an option in the macro for cross bracing to add a spacer plate? The binding plate connection only works for double angle bracing, not cross bracing. Currently I have to create my own plate and it is very difficult to make sure they are in the correct position and rotation.
Also, would it be possible to have it so the plate dimensions can be manually changed, either by projection or length/width.
