- Mute
- Permalink
- Report
is it possible to not have a assembly number to loose part?
i had one of the job which has basically only plates. After running the single part numbering, when time comes to create the plate list(BOM) it want generatevit due to the reason it didn’t had assembly number!
also in another scenario if I have bigger multi story building With made of assembly and loose part, I when I run the numbering I don’t wanna select all the loose part and give them single part number and than select assembly and then give them the number. Is it possible to just run the numbering with one go and let system decide not to give assembly number to single part and plus I wanna see those single part in selected BOM too.
