plate bevel not appearing on details ,fully
markhubrich
markhubrich
Hmm, my model shows the bevels but the details ignore some but not others.
no issues that can see on plate bevels in model.
They don't all show on detail or erection view.
Does anyone know what is causing this unwelcome phenomenon?
I wonder if it was the additional cuts..
Mark
...and fix the kiss export issues.
markhubrich
It doesn't like being combined with other cuts apparently. I removed the two little corner cuts and it's fine.
Sebastian_Eiche
the bevel cuts are a special modelobjects, maybe this are not shown in the erection detail style?
There's a modelboject "Weld preparation" this should be set to "visible", not sure if it's enough the beams had to set to "Visible(Exact).."
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
