Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Is there an option to do this connection?
2 REPLIES 2
eyal.ch
184 Views, 2 Replies
Hi All,
In AutoCAD I used to create a wind brace made of an angle and a threaded rod welded to it,
as you can see the rod penetrates the beam and connects withe a nut and an arc element,
and the threaded rod is welded to the angle.
Is there a connection similar to this in Advance steel?
How can I create this connection?
2 REPLIES 2
AleckGiles
in reply to: eyal.ch
Have you tried the connections on the "Rod Bracing Joints" page of the Connection vault?
Aleck Giles, Structures Consultant, Graitec
LinkedIn
eyal5168709
in reply to: AleckGiles
Hi @AleckGiles ,
Yes, I tried all of those connection for vain,
Maybe its a combination of angles and one of those connection,
There mist be a way to use angles as a wind brace that a threaded rod welded to it on both sides as on the picture,
It would be helpfull if someone knows how to do it.
Thank you.
Technology Administrators
