New line separator for user attributes
george1985
george1985
Is there some special character, which can be used to divide a project or object user attribute text, into different rows/lines?
For example, below shown text:
"This is first row text @ Second row text @ Third row"
Should in single part drawings appear as:
Second row text
Third row"
I used the "@" character, just as an example.
I tried both VBA and VBscript new line separators ("vbLf", "vbCrLf") but neither worked.
I understand that I can just put each text row into a separate User text:
But this approach will not work, as I already use some of those User text fields for different purposes.
I would be grateful for any kind of help on this line separation charater.
Thank you in advance.
mick-CNF
You can but what the special character is i'm not sure?
I copied the line from the line for Management Tools from the CUI box, there is something between the words if you scroll along in the line that makes a new line.
Screenshot 2024-03-18 083940.jpgScreenshot 2024-03-18 084046.jpgScreenshot 2024-03-18 084355.jpg
If this information solves your problem please accept as a solution.
bigcarl5000kg
Hi @george1985,
yes, it is possible, you need to use the separator "#Newline", which are normally used in the definition of the part description, after clicking on the special symbol - see red mark:
Example - beam properties (German version):
Result in the drawing (part description):
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
bigcarl5000kg
Disadvantages:
- when using the same values from User attributes in the parts list (BOM) - here example with UserAtt1 in BOM
Therefore, I recommend using the 10 available User attributes, I have not yet encountered a situation where there were not enough of them.
george1985
Thank you very much for the detailed replies and advices!
Both @bigcarl5000kg and @mick-CNF !
@bigcarl5000kgindeed, I didn't think on the effect it may have on BOM. Thank you for making a point about this as well.
