Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Can anyone help me troubleshoot column-beam (web side) connection issues?
1 REPLY 1
wuttiphat
156 Views, 1 Reply
Screenshot 2022-12-23 125949.jpgpic.1
Screenshot 2022-12-23 125913.jpgpic.2
Screenshot 2022-12-23 130151.jpgpic.3
Screenshot 2022-12-23 130231.jpgpic.4
pic. 5
          Well, now i have a problem about connecting beam to column (web side) because when using command same as the side that beam connect to column (pic.5 flange side) i.e. i want shop drawing to have. all the same size so that it will be the same standard if you don't understand Please open my DWG file to check.
          From Figure 1 you can see that I have highlighted the column because connecting the beam to the column on the flange side using the "I Bracing Splice Full Gusset Simple" command is incorrect.  I absolutely want the form to be connected it's like the 2nd picture, but I don't know how to do it. So i have to create another column that overlaps each other. to come as a reference point in order to connect to the flange side
         So the question is, how can I create a connection like in Figure 2 without having to create a dummy column?
The 3rd and 4th pictures have the same problems as the 1st and 2nd pictures.
1 REPLY 1
wuttiphat
in reply to: wuttiphat
I mean, I want what I'm moving in this photo to come out on the flange edge.
Technology Administrators
